I have a 96 Force Outboard that started giving me trouble this year probably due to bad fuel. It started out by stalling all the time at idle. I decarbed and then had a problem with stalling at idle and then bogging down and stalling when raising the throttle under way. Funny thing is that it would throttle up fine when in neutral throttle.
I just took the carb off this weekend and soaked it for a few hours in carb cleaner. I put the carb back on (looked like new) and it would start for a second or two but that's it. I pulled the plugs and the middle and bottom plugs were wet and and a little black. Top plug was dry and clean. Same thing after that. It just wouldn't remain running almost like it was getting too much gas.
Next thing I tried was starting the motor by manually holding the throttle open a bit on the carb. It finally started but stalled soon after. There is gas coming out of what looks like a vent in the side of the carb. Probably from the cup overfilling from all the gas used during all of the starting attempts. I am at a loss and not sure what to do next. I am heading to the store to grab a compression test kit. I will post the results.
