I recently used this motor for the first time in a couple of years, then hung it on a rack in the garage. Beneath the lower unit I noticed a bit of lower unit grease and some water on the floor. It seems to be coming NOT from the plug screws used for changing gearcase oil, but from a phillips head screw on the opposite site (from those plug screws) on the skeg area of the lower unit.
Any clues as to cause and fix? Will simply tightening it do the trick? I've done nothing yet.
Thanks in advance.
Thanks in advance.
