Alright, so I'm not a Marine mechanic, but I am rather mechanically sound. I pulled the boat (1989 Celebrity 231 Cuddy with Merc 350 Mag and Alpha 1 Gen1 outdrive) out and ran it with no trouble memorial day weekend. Since then I bought a Stingray Hydrofoil and pulled the lower unit off to install. No problems with the install. Took the boat out for the first time since and the strangest things happened immediately when I launched.
First, I have no neutral with the neutral button pressed. Instead I have forward gear as I would normally. I have no reverse at all and lastly with the neutral button not pressed, the engine dies as soon as I put it into forward gear. When I put in reverse, i have forward gear!?!?!?!!?!
So my assumption is that I must have misaligned something. I believe I was misinformed about removing the lower unit and may have had the throttle in forward for the removal/install. Any chance this is the culprit? Thanks in advance for everyone's help.
