Drive lube Leak
atomb
Ok guys heres the new one--- filled her up with new lube alpha one gen2 and shes weeping lube from the gear housing water drain hole on both the port and starboard side page 1 B-9 on manual.I would imagine theres a faulty seal.
I pulled the drive again .
i had some time learning how to get the drive back on in my last thread at least i kinda no what im doing now with that.
So any ideas ion which seal would cause her to weep lube from thhose water drain holes ? Thanks guys Im sure your all out boating and Im just wishing I was. wo es me..:(
And yes i did a impeller job 2 weeks ago.
Don S
Re: Drive lube Leak
Drain the gear lube and pressure check the drive, some soapy water sparyed on the leak will bubble and show you exactly what is leaking.
atomb
Re: Drive lube Leak
will do . Ill post results thanks don
atomb
Re: Drive lube Leak
well did the pressure test and found that she was leaking air from the upper where the driveshaft mates with the upper. So I proceeded to call a professional.
Unfortunately he needs to replace my quality workmanship of the waterpump ...no questions asked says its a liabilty for him. bang 225 (understandable) and the upper to dismantle and replace the seal will be min of a c note probably a bit more hopefully not too much but i looked at the expolded view of an actual drive he had on the wall and it looks like pia. He said the race and the bearing up top look good.
I get her back thursday . I think next time Ill hand the drive over it turns out it really wasnt worth my time to work on the drive myself for me. YMMV ----all he does is outdrives hes a professional and a nice guy to boot. Hopefully ill be making a splash this weekend I wouldnt put money on it but ill post an update.
he did say it was possible that when i put the drive together i might have knocked the seal loose with the drive shaft. I dont think i did but I just might of done that either way im done with it.
Cant wait to reinstall the drive:rolleyes: and make all the adjustments. Got bunks to change trailer lights to solder ...cant wait:rolleyes: oh yeah forgot up trim is on the fritz...yay
ill be back.
