I have a 12.5ft old zodiac soft bottom with inflatable keel. It has a 15hp short shaft.
Problem is, I cant get the bow up and out of the water when I plane off. It seems like the bow is being forced down witch causes terrible handling and a very wet ride.
I've tried adjusting the angle of the L/U to get the prop to push the stern down. Tried every setting. When I bring the prop out away from the transome, it cavatate's.
The trim tab plate of the outboard is about 1.5 inches below the bottom of the boat, which sounds O.k..
Does this problem sound like something a longshaft motor would fix?
P.S. The boat was empty, with just me in it while testing.
