Redfeathers kill
- Jul 3, 2010
- 18
I just bought a boat with an 78 merc out of the water she sounds great but in the water i can only get about 2100 rpms its seems to be running on only 3 cylinders. We checked for spark on all 6. All were getting good spark but when it is running you can pull off 1,3,5 with no change in the sound of the motor. If you pull of 2,4, or 6 the motor just about kills itself Could this be a bad cdi. for what its worth it when we covered the top 2 carbs (1 at a time ) the motor would just about die but when we cover the bottom (3rd) carb no audible or visual signs of the motor being affected by it. My mechanic thinks maybe the stator but he has the same motor with the opposite 3 cylinders not fireing and he tried a stator and then he got no spark at all. The big differance is that my motor shows spark on all 6 plugs but yet 3 of the cylinders are not running. please help me diagnose this problem because i cant afford to just keep dumping parts into this motor to see what works. Thanks
