OMC 3 liter IO won't start
cherylbentley
It doesn't seem to be getting any gas in the carburator. I disconected the fuel line and gas is reaching the end of the fuel line at the carburator. I took the filter out of the carburator - it was clear.<br />The motor seems to crank over OK but no gas. Tried starter fluid in hope of "priming" the gas flow.
Re: OMC 3 liter IO won't start
Time to take the carb apart.... Stuck needle valve, Clogged Jets, ????
Boatist
Well it could be a stuck float or something in the carb but before I pulled the carb off I would poor in a little gas and go crank. If it starts then you know it is a fuel problem. Check fuel pressure to carb if 4 lb then go ahead and work on carb.<br /><br />If it still will not start then I would check spark and make sure that is good before pulling carb.
