Hey all,
I did it! I finally got the boat out of storage and brought it back to the house! Its been over 2 year since i've had it on the water.
I am running twin AQ130C w/ 270 drives.
I spent all day yesterday siphoning about 55 gallons of old fuel out of the tanks (headache!)
Today, i hooked up a plastic fuel tank to the engines, primed them, checked the oil and impellers, charged the batteries, and got both engines running.....ish....
Now, I was hoping you swell fellows might be able to help me out with the overall tune-up procedure here.... after having it out of service so long what would be the proper way to get her water ready again? what would it consist of in your opinion?
1) Should i changed plugs, points, wires, impeller, etc.... or just check them and clean them up? I've never had anything sit so long, and want to spend the money wisely.
2) After a while the port engine started acting fuel starved... It died out and would only fire up if i put fuel in the carb, but after that burned up it would die. Does that seem like a fuel pump issue or a carb issue?
3) after sitting 2 years, would you recommend that i rebuilt all four carbs to be safe? or should i just clean them up and sync them?
4) Should i change the oil in the leg too? I had actually just changed the oil in both legs before putting the boat in storage....is that oil done for after sitting so long?
Any info or insight would be greatly appreciated.
