Which Smart Tabs?
Spowdrill
I just bought a 2005 Tahoe Q6 5.0 220hp and I am having a lot of trouble steering at low speeds and my planing is ok but I am sure it should be better.
I have read all the posts I could find on the smart tabs and I saw that people with hp ratings a little lower than mine were downsizing the chart a bit.
Question is, do you think I should downsize too? Would the extra 30 or so hp be enough to push me into the 80# category or should I go with the 60# ones?
Thanks,
Steve
Prophammer
Re: Which Smart Tabs?
Is It too late to change over to hydraulic trim tabs?
Spowdrill
Since this is my first boat, I am pretty much boat-ignorant. I have no idea if I can use hydraulic or not. If it requires a fair amount of attention to make sure it is at the right level then it probably wouldn't work in my case. I have a wife and teens that will be taking the boat out on occasion so I don't want them worrying about another thing to mess with. I have read where the smart tabs are just install and leave alone.
The 60# tabs will do fine.
Thanks Mccownk, I figured you would have the answer!
Steve
dhendersonm
If you are still having any doubts after reading the posts on this forum call Nauticus.
