Hello gentlemen I have a bit of a long winded question but here it goes. About a year ago my 84 johnson 90 developed a water leak in the lower starboard cylinder. I took the head off to discover that the block had erroded in one spot and my only option (that i know of) was to get a new block. The motor had been rebuilt less than 100 hrs before this so i opted to reuse my pistons and crank while all other wear parts were replaced. I wasn't confident in my ability to assemble the motor from scratch so i paid a knowlgeable local mechanic ( who also got me the new block from his parts yard) to build the powerhead. while doing this he offered to turn the motor from a 90/115 into a 140 with the upgraded carbs and exhaust housing. The block was machined to fit the stuffers for the 140 exhaust and it was bored 30 over to match my pistons. I dont however know what motor this block was originally from as he pulled it out of his parts yard. I have been running the motor for about 6 months now and it constanly fouls the plugs. the carbs are jetted to what the manual says a 78 140 (which is what the carbs came off of)should be. I'm running a 25 idle and a 65c main. I have been told conflicting reports about the 115 block being the same as a 140. Is it possible that i will need to run smaller jets because the ports on the 115 block are smaller than the 140?? Another possible problem is my thermostats are stuck open. I dont think he replaced them as it wasnt discussed when we made the deal. When i first start my motor on muffs it immediately starts dumping water out of the return vents and exhaust. Is this normal? I also have a shudder when trying to get on a plane around 2000-3000 rpms. This motor is on a 17 ft alum bass and has no trouble getting it up on plane and it tops out just over 50 mph . I will say it runs awsome once opened up and i am hitting 10mph more top speed than with the 90! It just has a terrible time idleing and at lower speeds. If i clean the plugs it will run fine for a while then start loading up after a while and soon it will barely idle. Pease help I love this motor and i know it should be running better than this!
