Re: What is a whales tail?
These devices work very well...but a few words of caution. In working well there is a fair amount of stress transferred to the "cavitation plate", attach the device as far forward (if one piece) as possible, to get to the meatiest portion of the lower unit plate. Make sure the device rests flat on the plate to transfer the stress as evenly as possible. Grind down the device flat at each attachment hole if there is any raised area around the hole. Next...BEFORE LAUNCHING...raise and lower, left and right the drive to be certain the device clears all obstructions on the transom, like ladders, ski harnesses, ropes etc.<br /><br />Last year I installed a new telescoping ladder...unfortunately did not check clearance and the "fin" caught the ladder and snapped a portion of the "cavitation plate off the lower unit. Also, a neighbor experienced fatigue (breakege) on his lower unit as a result of mounting the device too close to the edge of the cavitation plate. I am considering 2-piece plates so that they can be mounted forward on a heftier part of the cav plate and stay out of the way on my ladder, etc.<br /><br />They do work well........
