I am trying to bypass the vapor chamber on a 262 efi mercruiser. I have ran a fuel pump to the injectors and the engine starts, but as soon as you release the ignition key the injectors stop injecting. Any thoughts?
Theres an oil pressure switch near the oil filter that if not working or sees no oil pressure shuts down the Fuel system ( pump and/or injectors ) to help save the engine.
