Starting Assistance
atvarnell
I have a '98 merc 3.0 I/O.
i tried to start it after sitting for about 6 weeks. it slowly tried to crank, but no luck. I check my battery and alternator - good.
When i put the alternator back in, i failed to turn the battery off and caused a spark. Once I hooked it back up - no cranking or clicking. i had one fuse blow, which I replace, but still no luck. I have read several post and tired several things, but am confused more now.
When testing the key switch, I got no lights, but when I put a jumper wire from the pos. battery terminal on the front of the starter to the slave solinoid, it tries to crank. I tapped the solinoid a little, and it was even closer to cranking. If I move the jumper wire to the pos. terminal on the solinoid from the battery cable, it does not work.
Any suggestions? Thanks
Re: Starting Assistance
Ayuh,... You may have a little square fuse where the battery wire attaches to the starter...
If so, it's Blown...
atvarnell
is it the one where the battery (lg hole) is on one end and the wiring to the solinoid (small hole) is on the other end? I thought that was just for utilizing the 2 diffrent gauge wires. do you know what it is called?
thanks for your help
