I?ve done some repair work on my 30HP and I want to check/adjust the timing. The Johnson manual say the timing shall be 30 degrees BTDC with a test wheel at 5400 RPM. The WOT range for my motor is 5200 ? 5800 RPM. Since I don?t have a test wheel I ran the boat on the water and my WOT with two people was around 5700 RPM. With the boat at 5400 RPM the timing was right on, but when I opened the motor to WOT, the timing was higher than the 30 degrees. So my question is should the timing be reduced to the 30 degrees at the higher RPM, or should I leave it as is. It seems to me that as the motor spins higher, the timing should be higher as well.
Thanks in advance for any help
