jason32038
- May 25, 2009
- 555
I broke my rectifier on the old 85hp block trying to get the screw loose...my question is...can I cap the green and yellow wires off from the stator so I can try and start the new engine without the rectifier hooked up without overheating the stator? I need to get the timing and idle speed and idle mixture "kind of" set up until I get the new rectifier and get it in the water to make the final adjustments. CORRECTION!! I mean the green wires with the yellow stripe that go to the rectifier.
