meversole6
- Jun 29, 2010
- 5
i have a complete merc 302 with a cracked block and a good ford 302 out of a truck. does anyone know what all would have to be changed to make it work?
And these engines are externally balanced, and Ford changed the amounts of weigh carried in the flywheel and damper. If the truck engine is 81 or newer, you MUST use 81 and newer damper AND flywheel with it.
im kinda in the same boat, no pun intended lol. i have a 72 302 thats messed up, but have a crown vic police car motor i want to switch out. are you saying that the donor will be fine as long as we use the newer motors balancer and flexplate, or do we need to find some off of a 81 or newer boat?
Forget it. The modular engines were never used in a marine app, and cannot be used to replace a 302, even if somebody did make exhaust manifolds for them, which they don't.
