What tells the trim gauge the position of the motor?
C ckasper Recruit Joined Jun 29, 2010 Messages 1 Jun 29, 2010 #1 What tells the trim gauge the position of the motor?
HighTrim Supreme Mariner Joined Jun 21, 2007 Messages 10,486 Jun 29, 2010 #2 Re: trim gauge There is a sensor, follow the wires and you will see it.
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,938 Jun 30, 2010 #3 Re: trim gauge The sender is a rheostat usually mounted in the Outboard's transom bracket. It sends a variable resistance (to ground) to the gauge.
