Hey all,
Just repowered from a 1969 merc 1000 to a 1971 1150. A 4 wire regulator/rectifier had been added in place of original rectifier. I had a newer quicksilver tach hooked up to merc 1000 by switching "signal" wire to yellow rectifier wire and tach read accurately. Did the same wire switch on the 1971 1150. Motor screams, volt guage shows charging @ 13-14 when wot, but tach only says 4000 rpm. Quite sure tach is incorrect (only running 17p prop and last bit of throttle just over-revs motor. Seems correct @ idle around 800. Would regulator affect this? Is there a different procedure if you have a regulator/rectifier?
Thanks for any ideas.
