longhorn64
- Jun 29, 2010
- 2
Hello everyone,
New to the forum, great info here, my problem is I picked up a 14 foot flat bottom boat, wide bottom and the previous owner hit a stump so hard that it flipped the boat over put about a 1ft diameter dent in the front bottom of the hole left side. It twisted the hull so now the front left side of the boat is twisted up higher than the front right side. I tried to put it on a trailer, ratchet down the right back side, and then ratcheted down the left front side so that it was twisted beyond normal shape. i let it sit like this for about a month in 100 degree temp. but when I released it, it basically twisted back to the way it was. My question is, can this be fixed. I wanted to fix the dent, add a wood floor and cover the seats in wood but I would like to get it back to normal shape before I do this. Has anyone tackled this problem and if so how did you repair it. I thought about calling a body shop to see if they would be able to put it on a frame machine but wanted to check here first. thanks for all the help.
