I am getting close to reinstalling the fuel tank in my boat and I had a few quick questions I was hoping you guys could help me with. The fuel tank is an aluminum 85 gallon bellow deck tank.
1. Do I need to glue the tank in, or can I just try to clamp the tank down with wood or foam so it does not move?
2. The fuel fill line travels a far distance under the deck, and I wanted to secure the fuel line to the stringers. Would it be ok to use the cushioned stainless steel wire clamps to secure the fuel fill line and vent line? Is this over kill? Should just lay the fuel line on the hull of the boat?
Thanks,
Josh
Thanks,
Josh
