What problems are you having? Usually a dead cylinder:good compression but no change when a plug wire is pulled off.
Fill out your profile and tell us what's wrong.J
Yes, I have to push the key in to choke. When I do that there is a click I assuming is the primer valve or choke. After the motor is warm she fires up right away first time. I didn't quite understand what you meant by fuel bypassing the carbs on cold start. Doesn't the choke pump in a rich fuel mixure into the carbs? Sorry for the questions but I am slowing learning all I can.
Thanks,
Tom
