Re: Fuel pump Diaphragm and check valves How to??
Sorry, I just figured I would start with the diaphragm and check valves as they seemed to be an easy thing to do. The boat I am working on is a 1990 bayliner Capri 16' 90hp hell drive.
Short story of it:
Bought it with ignition issues, fixed those replaced stator cdi box (icm or whatever you call it) and coil packs. Had trouble timing it so brought it in and had it done. Ran good until the idle dropped to around 600 then would die while shifting etc. Let it sit over winter and started working on it again the other day. Tried just adjusting the carbs and got it to run good on muffs. Through it in the water, back down to low idle, and would only reach 2400 rpms. Took the carbs out cleaned all the jets etc reset the idle air screws back to 1.5 turns out (now know that might be a little too far, so am going to redo that) put it back togethor and runs pretty well. Took it to the river, and at first had low idle then after opening it up it started to idle good. Well after about an hour of cruising and just about to put it back on the trailer low idle again. Around 5-600. And on too of that reverse is inop now, but think it's just a cable or linkage issue.
Sorry if this is hard to understand I am just on my iPhone right now, so excuse my punctuation.
