ThemMuskieLures
- Jun 27, 2010
- 2
Hi,
I recently purchased a Track V16 boat with a Johnson 35 HP electric start motor. WHen running the motor, it idles fine and then when I throttle up, there's very little power and then after a minute or so, the throttle just kicks in and winds out. I am getting about 24 mph at WOT. Does this speed seem reasonable? Boat is 16 ft, 72" beam and weights about 600 lbs + gear and motor.
Here's what I have done so far.
1. New gas tank, primer bulb and new lines from tank to primer bulb and from primer bulb to motor.
2. I just removed the spark plugs and they were pretty fouled. I haven't had the boat out yet since replacing the plugs.
3. THe choke assembly seems to be functioning properly, althought when chocked, the valve is not completely closed, but pretty close.
As anyone seen this issue? I have been researching this tonight and it sounds like it could be a dirty carb, power pack etc.
Any help would be great.
Thanks,
Greg
Thanks,
Greg
