johnson 200
wse
I have a 1997 Johnson ocean runner 200 motor. I am having problems with beeping noise. I unpluged wiring harness that is coming from oil tank and beeping stops. would that meen the sending unit is bad? i would like to do away with oil injection without hurting the safty alerts if someone can walk me through it. any help will be greatly appreciated. THANKS
d.boat
Re: johnson 200
What does the beeping sound like?
What kind of warning system do you have - simple beep or System Check which has beeps and lights on tachometer?
Are you monitoring oil usage to see if it's burning approximately the right amount of oil?
wse
Re: johnson 200
d. boat thanks for the response. i found out that my low oil sensor has gone bad. thanks again. i think im still going to start pre mixing and do away with the oil injection.
