Re: Starting issues
Always do the cheap and easy first- cleaning the connections costs nothing, and it eliminates a suspect. Then try starting. If it works, problem solved. If not, the battery would be the likely culprit. Starting with the boost on the charger proves that. Even brand new batteries can be bad.
