Hello Guys ,
Great forum -glad i found it.
I have an 98' 8hp 2cycle that doesn't seem to want to pump fuel to the carb very well ,i changed the diaphram gaskets and it worked better for a short while -but now not pumping very well.
Also it seems to flood and wet the plugs easily ,i friend and shade tree mechanic adjusted the carb [his son has the same motor] .
Could someone give me a baseline on how many turns in or out with the carb screws please.
Should i buy a carb rebuild kit ?
The engine will purr like a kitten [sometimes] and not run others or purr like a kitten for two miles then quit-i've gotten good at rowing my Gheenoe 13'.
Thanks for any help.
Mike
Mike
