fat fanny
- Feb 9, 2006
- 1,935
After replacing the temp sensor on my 96 3.0LX (Sea Ray) still disconnected I went to start and nothing everything else works blower,bilge pump, lights, ect, but nada to ignition! Just before all this I did re-rap the wiring harness to the shift interupter,lub monitor bottle and temp sensor with elec, tape due to unravelling. First though check the fuse blown! replaced tried again and same result. Next step look up what the red and purple wire connects to checked all those connection seemed to be tight and no freyed and or chafed wires. I know from the chematic the red and purple stipped wire are prong #6 on wiring harness connector. My biggest ? is what should my next step be to help solve this issue? I have a few multi meters to test ohms and or continuty to run trouble shooting tests. Oh yea by the way the starter did engage for a second eough to rotate the engine maybe once before the fuse blew plus the engine was running and starting just fine last Sat. So thanx in advance for any help to my dilema.
