Re: 1990 225 evinrude
On the back of the gauge, you'll see a terminal marked "S" or sensor. Run a small jumper from that terminal to a ground. If the gauge pegs to full when grounded, the gauge is okay. In which case, the problem would be with the sending unit in the tank.
