mnypitboat
- May 31, 2010
- 1,091
I picked up this boat off eBay from a boat dealer for $2100. It is a 01 Tahoe Q7. It had a 350 mercruiser in it. When I bought it 3 years ago it only had 55 hours on it. The bar code sticker on the outdrive was still like new. The only problem was that the origional owner left it sit in their back yard for years then got it repoed. The seats were destroyed, the gelcoat was faded, the stripes were faded. All of the rear of the engine was rusted. It did not run. The ebay ad said it ran perfect.
OK well we settled on the price of an extra $800 off the origional ebay price of $2900. Then we had problems with getting the trailer registered, so he finally agreed to do it himself. OK on to getting it running. I had to rewire the electric fuel pump. Then it had a bad miss. I thought the worst, but it turned out to be 2 broken spark plugs. I gave it a complete tune up and it ran perfect. The water pump was leaking. Replaced it. About 3 weeks later after taking the boat out, on the way home, the whole rig got squirrelly behind the truck. Turned out the trailer rotted in the middle and split apart. OK bought a used trailer cheap. From all the rust on the engine the oil pressure sending unit broke off. Blew oil all over. Easy cheap fix.
OK last season we had to replace the power steering pump. Again rust related. Replaced both tilt relays. This year one of the fittings on my tilt went out. Replaced it.
All in all, 3 seasons without any major issues. I have since redone the upholstery, cut out a storage area under the driver console.
All this season we have had a tapping/pinging noise from the engine. It finally got really bad, so I tore down the engine. It looks like a factory blem in one of the head gaskets, but it caused damage to both of those cylinders. I bought an engine, thought I was getting a great deal and it turned out to have a dead cylinder. So I bought a rebuilt bottom end, and that is where it sits. Hopefully we will have it back together this weekend and back in the week after July 4th.
Here are some pics. Here are some before type pics. I will upload some more as time permits.
