Re: Primer bulb going flat
I had same problem, after alot of frustration I tracked it to my 6 gal tank, the hose inside the tank was getting sucked flat replaced the hose / filter not happened since. btw my primer bulb is origional at least looks that way still works fine, I would save the bulb for later in the troubleshooting process
