Re: Gear Oil Reservoir Overflowing
Had very simular problem on my 4.3, turns out that my lower leg gear oil plug gasket was shot and as I was moving the boat on the water the resivior was filling up ever so slowly pushing water back up to resivior, you couldn't notice any water in the resivior container until you remove it from the snap on clips and tilt it sideways....sure enuf there was a film of water sitting at the very bottom, which was forceing the gear oil out of the cap, not sure if this is your problem but it's worth looking at, turns out that all I needed was a $5.00 gasket for the lower leg gear case oil plug.
