Killer Bud
- Jun 23, 2010
- 1
I am wondering if I could get some help on the following things
#1: When I put power from the battery to green the trim goes down no problem. When I run it to blue, it does nothing. It just runs and runs withoug moving anywhere. Problem is, it worked fine 2 weeks ago, all I did is change the oil. Any ideas..?? I have bled this thing and there doesn't seem to be any air left in the system.
#2: I do not have the solenoid hooked up that was originally hooked up for the power trim. It is a 3 wire system. The plug going into the power trim is red, green and a light shade of blue. Coming out of the plug to the housing ( and to the solenoid eventually I presume ) is also red green and light blue. On the top of the electric motor I have a blue and a black. I presume the black is ground, and the blue should be up. I have no idea how to hook the solenoid up properly. Any help or a diagram is much appreciated.
Regards,
Regards,
