myboatneedswork
- Jun 23, 2010
- 1
I have a 1991 ebbtide 4.3l Yamaha inboard outboard boat with two problems that are keeping me from enjoying the water..
Problem 1,
The boat is not circulating water correctly.. When i have the ear muffs on, no water comes out of the pee holes. The pump is located on the right side of the motor and is driven by the belt... i know the pump is working because i took the water intake hose off and put a water hose down the intake hose and then it came out of the pee holes fine. I just don't think its getting to the pump correctly, there is no blockage from the stern drive to the pump. I am totally confused...
Problem 2,
The boat will not go into gear without the engine dieing, it has something to do with that kill switch that kills the engine for a microsecond to allow the gears to mesh smoothly. I can unhook that kill switch and the boat will go into gear, its just really rough. I noticed that when the boat is in gear the kill switch is closed.
Problem 1,
Problem 2,
