I have a 1967 6hp Evinrude Fisherman which will start and idle ok (not great), but the engine wants to die out if I try to open the throttle above the "start" position- either in gear or in neutral. Any ideas?
Things I've tried so far:
-Replaced and adjusted points and condensers
-Removed and cleaned out carb (not a rebuild)
-Removed and inspected spark plugs
-Replaced fuel
As a side note- one of the transom clamp screws is bent- anyone know where to buy these?
-Replaced fuel
