Re: Steering question First non-tiller outboard
No it is not normal but if it doesn't cause a problem I would probably leave it.
If you really want to chnge it then what you need to do is first turn the wheel all the way left and then all the way right taking note of how many turns it is stop to stop. Then position the wheel in the center of this range. If the wheel is centered in the range and isn't straight and you have a rotary system then the cable was probably inserted wrong. If this is the case then you would have to oull the cable out of the helm, position the wheel as described in the instructions for your helm, and re-install the cable. The wheel is keyed to the shaft and not splined like a car so you can't just pull the wheel off to get it centered correctly. With the wheel in the center of its turning range you now adjust the link arm between the end of the cable and the tiller horn on the motor to center the motor. Sometimes the link arm doesn't have adjustment, but you can get ones that do have an adjustment.
BTW, my lawn tractor turns just as sharp either right or left too.
