Re: 1993 250TXXR Oil not transferring to engine oil tank
OK I read and printed out the best of the posts. I think I understand the basics of the system. I removed and cleaned the remote tank, confirmed the pump is operating, change strainer. did a continuety test on the remote tank sender and it seams to work properly. Put in one gallon new TCW3 in remote tank. Drained engine tank and cleaned. Srainer good, the clover leaf baffles not in good shape. One is missing and the lower intact but ragged. I removed that ragged one fearing it would go down the strainer.
I checked continuity on the ECU on engine tank and this is what I got.
The plug has five wires Black, Blue/Red, Blue/Red, Blue/Green, Blue/White.
I checked continuity at the different switch levels SW1, SW2, SW3
One lead on black
SW1 - both floats up - continuity on blue/white only
SW2 - Top Float down - bottom float up - continuity on black and blue/green only
SW3 - both down - continuity on blue/green and both blue/reds
I reconnected the ECU to the motor harness outside the tank and with both up had a reading of green on the gauge, top float down bottom float up gauge stayed at green (no remote pump operation), both down alarms andgauge lights flashing.
I am not sure where to go from here. Is it a wire harness failure or is the engine ECU malfunctioning. What can I test to figure this out?
