Canman38
- Jun 11, 2009
- 23
I just purchased my first I/O. Its a 1988 Bomber Commander with a 5.0 OMC Cobra 2bbl. I got pretty familar with my evinrude outboard, but this thing is a little different.
I hear everybody throttling their engine in nuetral. I know it sounds dumb, but I havent been able to figure out how to do this. I just tried starting the engine on muffs for the first time since last year. I cranked and cranked the engine, and it really wouldnt do much but spudder once in a while. So I figured if I put it in gear and pumped the throttle by pushing all the way forward on the throttle control before I started it, I could get some squirts of fuel from the accelerator pump to help start. It worked, but would then slowly stall out.
I figured it would have a fast idle when the choke was closed but I looked at the carb and there are no steps on the fast idle cam, just kinda smooth all the way around. And doesnt move the throttle no matter where the choke is. So I couldnt figure out how to keep it running when it was cold, so I disconnected the throttle cable and worked the throttle right on the carb by hand while the drive was in nuetral.
Once it I ran it for a few minutes it seemed to start and idle ok and the throttle was pretty responsive.
I searched for an answer but I think it is too elementry for discussion.
I appreciate your help.
