I need to verify that this link http://internetoutboards.com/partdetail.asp?id=626 is for the correct service manual for this engine 1989 Nisson NS 70 A2. I would also like to ensure that this manual covers the troubleshooting steps and techniques to verify/isolate faulty ignition problems as well as how to check timing and perform the link and sync proceadure that an average gearhead can understand and follow.
I am having problems with idle quality and slow to mid speed transition on this engine. I have clean carbs and new plugs and have performed the de-carb proceadure as found on this site using both deep creep 3/4 can after warming engine and loading it up and let sit overnight with the spray can and then the 3 time 15 minute run and wait with 3/4 gallon of gas/3oz oil and 16oz can of sea-foam and it still runs like crap! I have compression checked it hot at 120 on both cylinders with both plugs removed and gauge in one plug hole at a time.
I want to verify timing and then check for spark/ignition problem to find out what is going on. I do not want to put a lot of money in this engine. If I cannot get it running good for a few hundred then I'm going to look for a different engine.
If I buy this service manual will I be able to get some help diagnosing this engine?
Thanks
Thanks
