I have been trying to find a wiring diagram for the relay block. My trim doesn't go up or down and the motor is fine if you jump the wiring everything works(new trim control as well). While checking with a voltmeter at the relays(new) every once in a while it worked so I am guessing I have a short. But, I would like to find a diagram to ensure everything goes where it should when I rewire it. Anyone have a clue where I can find one?
