Re: 50hp FORCE revs way up on its own
There are different interpretations on Regular and Premium, but my advice is just to not use anything that says "10% Ethanol Added" or anything that says anything about ethanol. But I dont think that is your root problem here.
You will get some performance difference between being on the lake, being in a test tank, or running on muffs because of the water resistance on your prop.
Intermittent or seemingly random problems are the hardest to diagnose, but if you want it to run right you are going to either diagnose it yourself or pay a mechanic $xxx to do it. With that being said here is what I would do:
The cylinder drop test told you the ignition is "probably ok". But I would first buy the factory force manual for whatever year and model motor you have. (I got mine on ebay for $12) Also buy a multimeter (I got one for $30) and a DVA adapter (I got one for $35)
Test the ignition system. The manual walks you through all the steps, and tells you where to put the leads.
These tests will either certify that it is a problem with one of your ignition components, or it will certify that your ignition is ok.
The reason I am saying check the ignition is because I had a similar problem with mine and I thought there was no way it could be ignition, but turns out that it was. I wish I would have tested it right from the beginning because I would have saved time and money, which is what everyone here is trying to help us all do. Good luck and I hope you get her running!
