1992 sea ray 220 floor
EJL
Does anyone know if the floor in a 92 sea ray br is wood or composite?
Bob_VT
Re: 1992 sea ray 220 floor
Welcome to iboats.
Probably fiberglass over plywood. Is the deck soft?
EJL
I'm going to look at the boat today so I dont know. Owner says it's solid? Anything I should check?
Bob_VT
Stomp around on the deck like a child on his toes ;) you will find soft spots. If you are considering buying it...... do the best you can looking for rot and wet wood.
A small screwdriver will push right into rotted wood....check the inside of the transom by the bottom.
