motor had sit for a few years, but after a few hours work it would start up but only run on 1-3, 2-4 had no spark at all, tried a new power pack but still no spark on2-4... then for some reason all 4 cylinders had a great spark(bright blue) but a week later was getting a weak spark on all 4 cyl. Got a DVA.started with the stator first,,, brown/brown-yellow= 180 volts,,,,brown too ground180volts,,,,brown-yellow too ground 260 volts.....coils range from 159-172 volts ...then I tired the white to purple.6volts,whiteto blue 1.2 volts,white too green .5volts, white too red got zero,so I check the spark again at the plugs and had no spark too any plug..I check the white to all 4 wires for ohm test an looks like a dead short,unplug power pack and all 4 wires test 42 ohms.. I unplug the black an yellow wire and no diffrence.I take it the power pack is now dead also.......
