Hello I have a 1972 Evinrude Sportwin 9.5 (model 9222m). I bought a new fuel line and tank as well as plugs wires and fuel lines. At any rate I put it in a test tank and it runs great, until it place the lid on, then it bogs down just above an idle with little power, I did observe some of the foam loose and took it out just so it could not block the intake. I also drilled 3 3/8th holes inside and under the lid handle with no change in the problem. I search the site for this topic on this engine and didn?t find anything, but any direction, advice or help would be great, thank you in advance.
