Boat is a '99 Chaparral Sig 27 with a 7.4 MPI Bravo 3.
Today was the first day of break in on the new motor after a 2 months of boat woes getting this project completed. The new motor ran great. Other than I had the coolant reservoir too full, the reman'd motor is real strong runner. I replaced the y-pipe o-ring before installing the engine just because I had time.
I noticed some water in the bilge while on the lake. I broke my trusty flashlight and was expecting something different. I saw consistent water drips falling off the trim pump hoses. Naturally I suspected the bellows had developed a crack and was water was coming through my gimbal bearing. I turned the wheel in both directions which had no effect on the flow whatsoever.
On closer inspection, the water seems to originate ABOVE the gimbal bearing/shaft opening where the steering lever goes through the transom. There was water on the lever opening, but not on the lever itself. Because of the way the transon assy is built, the water flows around the bearing. I have not removed the drive to see if the bellows is also leaking, but there's no water shooting above the u-joint shaft.
I looked at the service manual for guidance, but I have questions. I think I know the answers, but...
1) If the the steering lever opening is indeed the source, is there a bushing or seal to keep water out?
2) If there is a steering lever shaft seal, do I have to remove the transom assembly to make the repair or can I remove the bell housing and go that route?
3) If the steering lever shaft opening does not have a seal of it's own, can I assume the the transom seal is what is actually leaking?
4) We're still unusually wet n nasty with Spring weather in the Pacific Northwest so the 2010 boating season is going to be pretty short. If the transon assy seal/o-ring is the culprit, could I use a sealant around the transon assy as a short term fix AND OR determine if it's leaking.
I just had the engine out of the boat so I'm reluctant to pull it again, but having water coming into the boat...well...just ain't right!
Any thoughts are greatly appreciated.
Kevin
Kevin
