Re: What is the difference in plugs
If two or more plugs are in the current recommended list you can use either. The first one listed will be the preferred one though if there is any preference.
With Champion plugs the
higher number is hotter than a lower number
( with NGK plugs and Denso plugs the lower number is hotter. Dont know about other makes without looking it up)
Look up the latest recommendations
HERE
EDIT
Just read elsewhere on the forum that someone prefers the QL82C for trolling because its just that little bit hotter. You may want to experiment to discover which suits your needs better
