Re: Trouble getting pinion gear back in place during LU rebuild - '86 Evnrde 90 HP
Rig up something so that you can have the lower unit secured in a upside down position.
Now, have the pinion nut sitting on the pinion gear..... where it would normally sit.
Carefully have the pinion and nut balanced on the blade of a large screwdriver or a tool of your choice and slowly slide it into the gearcase, into the area where the pinion would normally sit.
Now, while watching the pinion and nut, slowly slide the driveshaft upwards into the gearcase, watching to see when it makes contact with the pinion (turn d/shaft if needed to have the splines align).
As the driveshaft makes contact with the nut, carefully (very carefully) turn the nut in a clockwise rotation to have it thread onto the driveshaft splines. When done, be absolutely sure to torque that nut to factory specifications.
If the driveshaft and nut threads are in perfect condition, the nut will thread on with no problem. Let us know how you make out.
