Re: minn kota speed problem
The issue is that with the prop stalled and power to the motor, something in the speed controller burned out due to the high current draw. Is there a fuse or circuit breaker at the battery for this troller. If not, you need one and it probably would have saved the motor. This has nothing to do with what's now damaged. Since we have no idea which motor you have or how old it is, it's hard to tell where the issue is. Since this is apparently a speed coil type of system the speed coils are in the motor. If it is a power drive type of motor than either the board in the foot pedal or the motor can be damaged.
