erichy
- Apr 3, 2010
- 57
Hello everybody I'm back with more questions on my nightmare boat (what do I expect for 300 bucks). My latest issue is the adjustment on the shift linkage won't catch forward and reverse at the same time. On land it's fine but in the water it won't do both. Today I put it in the water and adjusted the linkage until it barely made it into reverse then forward didn't work. I adjust it so it barely goes into forward and reverse won't work. The other thing is my trim is not working, the motor is running with the switch bow up or down but no movement. Any info you guys could provide would help a ton because I'm going broke throwing money at this thing.
