Force 125 Trim/Tilt Leakdown
Brandon13
I know that it's a common problem for the trim/tilt to have leakdown problems. However, my question is...can it be fixed? I've read where people recommended changing the valve seal. I was also told by a local Force mechanic that it's something you have to live with...Any ideas? Thanks
RRitt
Re: Force 125 Trim/Tilt Leakdown
its not something you have to live with. You can buy new valve body for $220ish, you can have existing rebuilt for $110ish, or you can swap out whole pump for $230ish.
Brandon13
How much am I looking at for rebuilding it myself? What needs to be replaced? Pilot valve seals?
RRitt
usually about $110 to $230 depending which way you decide to go after spending a month or so mucking around with it. very few people get reliable results doing it themselves.
Brandon13
How common is it for the problem to just be the valve seals? Don't really want to dump 100+ into it, but I would like to fix it. However, I don't wanna mess it up trying to replace the seals. Haha I know it sounds like a pick your poison.
RRitt
it is always the seals. just learn to live with it. if you open it up then you are most likely to lose power tilt altogether. If that happens then you won't be able to get on-off trailer.
