Boat had been running great. Started to have sluggish starts over the course of a couple weeks. However, once boat was up and running, could easily start when needed. Boat sat for another 2 weeks, and not I turn the key and the starter clicks into the flywheel, but doesn't turn.
Charged both batteries (which were low) and clean corrosion that had built up. Tried to start last night and same ordeal. Started clicks into flywheel but doesn't turn.
Took started off. Starter felt a little warm.. Took battery cables and hooked starter to battery and it turned over fine.
Little confused.
If the starter is turning with the direct connection to the battery, started can't be bad can it? I am wondering if I should try new battery cables, or is there a possibility that the started can turn when it doesn't have the weight of the flywheel against it?
Little confused.
